[gdal-dev] Convert shapefile to SQL text for PostGIS
Aleksey Naumov anaumov at gmail.com
Tue May 11 12:09:53 EDT 2010
Dear GDAL users,
Is there a way to use ogr2ogr or other means to convert a layer (e.g. a
shapefile) into an SQL text file suitable for insertion into PostGIS? In
other words, a file with SQL text like:
INSERT INTO "my_table" ("the_geom" ) VALUES (GeomFromEWKT('SRID=-1;POLYGON
(( ...))'::TEXT) );
which could be read into PostgreSQL later. Ideally, I am looking for a
direct conversion, i.e. not involving PostGIS.
Thank you,
Aleksey
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100511/79b45792/attachment.html
