[gdal-dev] Python (2.6.5) GDAL module will not install with easy_install
Allen Rongone arongone at aer.com
Tue May 11 13:40:36 EDT 2010
On May 11, 2010, at 1:19 PM, Brice Lambi wrote:
> What is your python path?
> # python
>>>> import sys
>>>> sys.path
> What does that say?  It might have linked against the wrong version of
> gdal or it might be finding another gdal library in your path.  If you
> are using the default python (/usr/bin/python) it is probably finding
> something in /usr/lib before /opt/GEOSR/local.
Here is the output from the command above:
[root at psd14 ~]# python
Python 2.6.5 (r265:79063, May  3 2010, 14:23:56)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-46)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
 >>> import sys
 >>> sys.path
['', '/opt/GOESR/local/lib/python2.6/site-packages/setuptools-0.6c11-
py2.6.egg', '/opt/GOESR/local/lib/python2.6/site-packages/numpy-1.4.1-
py2.6-linux-x86_64.egg', '/opt/GOESR/local/lib/python2.6/site-packages/
scipy-0.7.2-py2.6-linux-x86_64.egg', '/opt/GOESR/local/lib/python2.6/
site-packages/matplotlib-0.99.1.1-py2.6-linux-x86_64.egg', '/opt/GOESR/
local/lib/python2.6/site-packages/GDAL-1.7.2-py2.6-linux-x86_64.egg',
'/opt/GOESR/local/lib/python26.zip', '/opt/GOESR/local/lib/python2.6',
'/opt/GOESR/local/lib/python2.6/plat-linux2', '/opt/GOESR/local/lib/
python2.6/lib-tk', '/opt/GOESR/local/lib/python2.6/lib-old', '/opt/
GOESR/local/lib/python2.6/lib-dynload', '/opt/GOESR/local/lib/
python2.6/site-packages']
[root at psd14 ~]# which python
/opt/GOESR/local/bin/python
There still exists version 1.4.4 of gdal and gdal-devel from the Red
Hat build, on this system, but they don't show up in the path.
Is there a way to back out everything?
Then I could remove gdal 1.4.4. with yum and try to install from the
tarball again.
Does this make sense?
Sorry for all the trouble...
~ Allen
> Allen Rongone wrote:
>> Brice,
>>    I think I was using the tarball specific to the python module. I
>> think I downloaded the correct one now - gdal-1.7.2.tar.gz
>>    I ran the configure script as such:
>>    # ./configure --prefix=/opt/GOESR/local --with-python
>>    Then a make
>>    # make
>>    Then a make install
>>    # make install
>>    Everything seemed fine until I tried to import the module in
>> python.
>> I got this when I tried:
>>> [root at psd14 gdal-1.7.2]# python
>>> information.
>>>>>> from osgeo import gdal
>>> Traceback (most recent call last):
>>>  File "<stdin>", line 1, in <module>
>>>  File
>>> "/opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-py2.6-
>>> linux-x86_64.egg/osgeo/__init__.py",
>>> line 21, in <module>
>>>    _gdal = swig_import_helper()
>>>  File
>>> line 17, in swig_import_helper
>>>    _mod = imp.load_module('_gdal', fp, pathname, description)
>>> ImportError:
>>> linux-x86_64.egg/osgeo/_gdal.so:
>>> undefined symbol: GDALGetMaskFlags
>> Any ideas why I'm getting the ImportError with the undefined symbol?
>> Thank you very much for your help,
>> Allen Rongone
>> On May 6, 2010, at 12:47 PM, Brice Lambi wrote:
>>> Hi Allen,
>>> Are you compiling from source?  When I install gdal python I just go
>>> into the swig/python directory and run 'python setup.py install'.
>>> This
>>> should work.  The steps I take:
>>> tar zxvf gdal-1.7.1.tar.gz
>>> cd gdal-1.7.1
>>> ./configure --prefix=/usr
>>> make
>>> make install #run as root
>>> cd swig/python
>>> python setup.py install #run as root
>>> Hope this helps.
>>> Cheers,
>>> Brice
>>>> Hello All,
>>>>   New here so don't beat me up to bad.
>>>>   I'm trying to get the GDAL module to install on a Red Hat
>>>> Enterprise
>>>> Linux 5.4 64-bit workstation running Python 2.6.5.
>>>>   I have installed the setuptools 0.6c11 and am using easy_install
>>>>   My gdal-config is in /usr/bin, however, when I run easy_install
>>>> GDAL
>>>> it complains that it "Could not run gdal-config!!!" and then
>>>> contiues on
>>>> complaining about a bunch of stuff not
>>>>   being declared.
>>>>   I can not find the setup.py to edit and change the location of
>>>> gdal-config. easy_install must clean everything up if it fails.
>>>>   Does anyone know how to get this to work or will we have to do
>>>> without GDAL in python?
>>>> Thanks for any help,
>>>> Allen
>>>> I've included everything I thought pertinent below:
>>>> [root at psd14 ~]# uname -a
>>>> Linux psd14.aer.com 2.6.18-164.15.1.el5 #1 SMP Mon Mar 1 10:56:08
>>>> EST
>>>> 2010 x86_64 x86_64 x86_64 GNU/Linux
>>>> information.
>>>> KeyboardInterrupt
>>>> [root at psd14 ~]# which gdal-config
>>>> /usr/bin/gdal-config
>>>> [root at psd14 ~]# easy_install GDAL
>>>> Searching for GDAL
>>>> Reading http://pypi.python.org/simple/GDAL/
>>>> Reading http://www.gdal.org
>>>> Best match: GDAL 1.7.1
>>>> Downloading
>>>> http://pypi.python.org/packages/source/G/GDAL/
>>>> GDAL-1.7.1.tar.gz#md5=38b838d528b309a28a3aa24d4fcef3cd
>>>> Processing GDAL-1.7.1.tar.gz
>>>> Running GDAL-1.7.1/setup.py -q bdist_egg --dist-dir
>>>> /tmp/easy_install-eKZHzW/GDAL-1.7.1/egg-dist-tmp-siVuDI
>>>> Could not run gdal-config!!!!
>>>> cc1plus: warning: command line option "-Wstrict-prototypes" is
>>>> valid for
>>>> Ada/C/ObjC but not for C++
>>>> extensions/gdal_wrap.cpp: In function $(B!F(Bint
>>>> GDALDriverShadow_Rename(GDALDriverShadow*, const char*, const
>>>> char*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:3371: error:
>>>> $(B!F(BGDALRenameDataset$(B!G(B was not declared in this scope
>>>> extensions/gdal_wrap.cpp: In function $(B!F(BCPLErr
>>>> GDALDatasetShadow_CreateMaskBand(GDALDatasetShadow*, int)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:3744: error:
>>>> $(B!F(BGDALCreateDatasetMaskBand$(B!G(B was not declared in
>>>> this
>>>> scope
>>>> extensions/gdal_wrap.cpp: In function $(B!F(Bchar**
>>>> GDALDatasetShadow_GetFileList(GDALDatasetShadow*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:3747: error: $(B!F(BGDALGetFileList$
>>>> (B!G(B
>>>> F(BGDALRasterBandShadow*
>>>> GDALRasterBandShadow_GetMaskBand(GDALRasterBandShadow*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4077: error: $(B!F(BGDALGetMaskBand$
>>>> (B!G(B
>>>> GDALRasterBandShadow_GetMaskFlags(GDALRasterBandShadow*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4080: error: $(B!F(BGDALGetMaskFlags$
>>>> (B!G(B
>>>> GDALRasterBandShadow_CreateMaskBand(GDALRasterBandShadow*,
>>>> int)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4083: error:
>>>> $(B!F(BGDALCreateMaskBand$(B!G(B was not declared in this scope
>>>> extensions/gdal_wrap.cpp: In function $(B!F(Bvoid
>>>> GDALColorTableShadow_CreateColorRamp(GDALColorTableShadow*, int,
>>>> const
>>>> GDALColorEntry*, int, const GDALColorEntry*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4147: error:
>>>> $(B!F(BGDALCreateColorRamp$(B!G(B was not declared in this
>>>> scope
>>>> ComputeProximity(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>> char**,
>>>> int (*)(double, const char*, void*), void*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4306: error:
>>>> $(B!F(BGDALComputeProximity$(B!G(B was not declared in this
>>>> scope
>>>> RasterizeLayer(GDALDatasetShadow*, int, int*, OGRLayerShadow*,
>>>> void*,
>>>> void*, int, double*, char**, int (*)(double, const char*, void*),
>>>> void*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4342: error:
>>>> $(B!F(BGDALRasterizeLayers$(B!G(B was not declared in this
>>>> scope
>>>> Polygonize(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>> OGRLayerShadow*, int, char**, int (*)(double, const char*, void*),
>>>> void*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4362: error: $(B!F(BGDALPolygonize$(B!
>>>> G(B
>>>> FillNodata(GDALRasterBandShadow*, GDALRasterBandShadow*, double,
>>>> int,
>>>> char**, int (*)(double, const char*, void*), void*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4378: error: $(B!F(BGDALFillNodata$(B!
>>>> G(B
>>>> SieveFilter(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>> GDALRasterBandShadow*, int, int, char**, int (*)(double, const
>>>> char*,
>>>> extensions/gdal_wrap.cpp:4394: error: $(B!F(BGDALSieveFilter$
>>>> (B!G(B
>>>> RegenerateOverviews(GDALRasterBandShadow*, int,
>>>> GDALRasterBandShadow**,
>>>> const char*, int (*)(double, const char*, void*), void*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4408: error: invalid conversion from
>>>> $(B!F(BGDALRasterBandShadow*$(B!G(B to
>>>> $(B!F(BGDALRasterBand*$(B!G
>>>> (Bextensions/gdal_wrap.cpp:4408: error:   initializing argument 1
>>>> of $(B!F(BCPLErr GDALRegenerateOverviews(GDALRasterBand*, int,
>>>> GDALRasterBand**, const char*, int (*)(double, const char*, void*),
>>>> void*)$(B!G
>>>> (Bextensions/gdal_wrap.cpp:4408: error: invalid conversion from
>>>> $(B!F(BGDALRasterBandShadow**$(B!G(B to
>>>> $(B!F(BGDALRasterBand**$(B!G
>>>> (Bextensions/gdal_wrap.cpp:4408: error:   initializing argument 3
>>>> void*)$(B!G
>>>> (Bextensions/gdal_wrap.cpp: In function $(B!F(Bint
>>>> RegenerateOverview(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>> const
>>>> extensions/gdal_wrap.cpp:4421: error: invalid conversion from
>>>> (Bextensions/gdal_wrap.cpp:4421: error:   initializing argument 1
>>>> void*)$(B!G
>>>> (Bextensions/gdal_wrap.cpp:4421: error: invalid conversion from
>>>> (Bextensions/gdal_wrap.cpp:4421: error:   initializing argument 3
>>>> void*)$(B!G
>>>> $(B!F(BGDALTransformerInfoShadow*
>>>> new_GDALTransformerInfoShadow(GDALDatasetShadow*,
>>>> GDALDatasetShadow*, char**)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4445: error:
>>>> $(B!F(BGDALCreateGenImgProjTransformer2$(B!G(B was not
>>>> declared in
>>>> this scope
>>>> GDALTransformerInfoShadow_TransformPoint__SWIG_0
>>>> (GDALTransformerInfoShadow*,
>>>> int, double*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4456: error:
>>>> $(B!F(BGDALUseTransformer$(B!G(B was not declared in this scope
>>>> GDALTransformerInfoShadow_TransformPoint__SWIG_1
>>>> double*, int, double, double, double)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4468: error:
>>>> GDALTransformerInfoShadow_TransformPoints
>>>> int, int, double*, double*, double*, int*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4550: error:
>>>> extensions/gdal_wrap.cpp: In function $(B!F(BGDALDriverShadow*
>>>> IdentifyDriver(const char*, char**)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:4661: error:
>>>> $(B!F(BGDALIdentifyDriver$(B!G(B was not declared in this scope
>>>> extensions/gdal_wrap.cpp: In function $(B!F(BPyObject*
>>>> _wrap_ReadDir(PyObject*, PyObject*)$(B!G(B:
>>>> extensions/gdal_wrap.cpp:5255: error: $(B!F(BVSIReadDir$(B!
>>>> G(B was
>>>> error: Setup script exited with error: command 'gcc' failed with
>>>> exit
>>>> status 1
>>>> [root at psd14 ~]#
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
