[gdal-dev] Python (2.6.5) GDAL module will not install with easy_install
Allen Rongone arongone at aer.com
Thu May 13 13:52:03 EDT 2010
Brice,
	Thank you.
	I removed the older version of gdal that came with RHEL, placed the
correct path in ld.so.conf and now it installs properly and I can
import the module in python!
~ Allen
On May 11, 2010, at 3:57 PM, Brice Lambi wrote:
> There is really no reason to remove the 1.7.2 you've built.  If you're
> going to install in the same location then all will be overwritten, if
> you install in a new location then it might be best to cleanup the
> unused stuff.  I think you can do 'make uninstall' as well.
> Cheers,
> Brice
