[gdal-dev] Re: Hoe to convert ERDAS imagine(.img) files to ARC info ASCII files viceversa
Iván Sánchez Ortega ivan at sanchezortega.es
Tue May 18 05:25:19 EDT 2010
El 18/05/2010 11:05, mail2vajram escribió:
> I saw that utility in the fwtools\bin folder.
*Use* the utility.
If you really must do this using C#, do read the documentation and
examples: http://trac.osgeo.org/gdal/wiki/GdalOgrInCsharp
You can skip C# altogether and use batch scripts, powershell thingies,
whatever. There are hundreds of ways to convert files from one format to
another.
Iván Sánchez Ortega <ivan at sanchezortega.es>
