[gdal-dev] Re: conversion from one format to another is very slow
SriRam.PrasadBhasker at rmsi.com SriRam.PrasadBhasker at rmsi.com
Wed May 19 07:50:50 EDT 2010
hi.
as far as i know GDAL is much robust & Quicker.
i have converted Tiff to Ascii using Gdal 1.6.2 & found the performance
excellent
Gdal converted in 3 minutes and ArcGIS took around 7 to 8 minutes for the
same task..
Trust you are using the latest Build of 1.7.2..
cheers
Bhasker
             mail2vajram
             <mail2vajram at gmai
             l.com>                                                     To
             Sent by:                  gdal-dev at lists.osgeo.org
             gdal-dev-bounces@                                          cc
             lists.osgeo.org
        Subject
             05/19/2010 05:16          format to another is very slow
             PM
yeah,
i did the same task with ARCGIS it took only 2 minutes only but the output
of the two datasets(gdal,ARCGIS) are same.
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/conversion-from-one-format-to-another-is-very-slow-tp5073787p5074562.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
