[gdal-dev] coordinate transformation with java library
ahmet temiz ahmettemiz88 at gmail.com
Wed May 19 09:10:05 EDT 2010
hello
Thank you Ivan for your quick response
I am using Ubuntu Linux.
 I need to know geographic coordinate values of a point which is in
UTM projection.
transformation something like  UTM -> geographic coordinate (32636 ->  4326)
Which JTS library do it ? ( I have already been using it )
thanks
2010/5/19 Ivan Lucena <ivan.lucena at pmldnet.com>:
> Ahmet,
> Here is one example that you can find on GDAL source tree /swig/java/apps:
> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/java/apps/gdaltransformer.java
> What OS are you using?
> You can get the library from OSGeo4W [1] for Windows is that is the case.
> Other alternative?
> Geotools [2] or JTS Topology Suite [3] maybe, depending what you need, just coordinate transformation, data conversion, what kind of data, etc.
> Regards,
> [1] http://trac.osgeo.org/osgeo4w/
> [2] http://geotools.org/
> [3] http://www.vividsolutions.com/jts/jtshome.htm
>>  -------Original Message-------
>>  From: ahmet temiz <ahmettemiz88 at gmail.com>
>>  To: gdal-dev at lists.osgeo.org
>>  Subject: [gdal-dev] coordinate transformation with java library
>>  Sent: May 19 '10 07:40
>>  hello
>>  I need to do coordinate transformation in my java application
>>  from UTM to geographic coordinates.
>>  Does gdal have any jar library that can do this transformation ?
>>  if there is
>>  whare can I find it ?
>>  What might be the other alternatives ?
>>  regards
>>  Ahmet Temiz
>>  Turkey
>>  _______________________________________________
>>  gdal-dev mailing list
>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
