[gdal-dev] NetCDF driver in gdal_translate ignores xllcorner and yllcorner?
Chris Barker Chris.Barker at noaa.gov
Thu May 20 23:26:37 EDT 2010
Ole,
The netcdf data model is pretty different than the GDAL data model, I"m
not surprised that GDAL can't figure out the grid.
Can you just go hand-edit the AAIGRID?
If  you need to script this, I'd tend to look for another solution -- it
would be pretty easy to parse the ncdump output and write an AAIGRID
from  it, or red the netcdf another way -- if it were me I'd use Python
and one of the netcdf modules. writing an AAIGRID is pretty trivial.
I'm guessing you could do something with a vrt too, but I don't quite
get that yet.
-Chris
Ole Nielsen wrote:
> Dear GDAL developers
> I have been using GDAL for a while with great success and really appreciate
> the toolkit.
> As of recently, I now have the need to read NetCDF files and convert them
> into AAIGRIDs. However, the cellsize is wrong and I don't think xllcorner
> and yllcorner are correct either.
> I have searched this forum and I think this may be related to the thread
> named "[gdal-dev] netcdf to geotiff and aaigrid" from 2008. However, I
> didn't find a resolution in that thread - hence this posting.
> The content of the NetCDF file is obtained by running ncdump merapi.res.nc:
> netcdf merapi.res {
> dimensions:
>         x = 59 ;
>         y = 64 ;
>         alt = 6 ;
>         time = UNLIMITED ; // (4 currently)
> variables:
>         float x(x) ;
>                 x:units = "m" ;
>                 x:description = "UTM. West-East distance" ;
>         float y(y) ;
>                 y:units = "m" ;
>                 y:description = "UTM. South-North distance" ;
> .... (many lines removed here)
> data:
>  x = 412432.3, 413449.5, 414466.8, 415484, 416501.2, 417518.5, 418535.7,
>     419553, 420570.2, 421587.4, 422604.7, 423621.9, 424639.1, 425656.4,
>     426673.6, 427690.8, 428708.1, 429725.3, 430742.6, 431759.8, 432777,
>     433794.2, 434811.5, 435828.7, 436846, 437863.2, 438880.4, 439897.7,
>     440914.9, 441932.2, 442949.4, 443966.6, 444983.8, 446001.1, 447018.3,
>     448035.6, 449052.8, 450070, 451087.3, 452104.5, 453121.8, 454139,
>     455156.2, 456173.5, 457190.7, 458207.9, 459225.2, 460242.4, 461259.6,
>     462276.9, 463294.1, 464311.3, 465328.6, 466345.8, 467363.1, 468380.3,
>     469397.5, 470414.8, 471432 ;
>  y = 9106709, 9107724, 9108740, 9109756, 9110772, 9111788, 9112804, 9113820,
>     9114836, 9115851, 9116867, 9117883, 9118899, 9119915, 9120931, 9121947,
>     9122962, 9123978, 9124994, 9126010, 9127026, 9128042, 9129058, 9130073,
>     9131089, 9132105, 9133121, 9134137, 9135153, 9136169, 9137185, 9138200,
>     9139216, 9140232, 9141248, 9142264, 9143280, 9144296, 9145311, 9146327,
>     9147343, 9148359, 9149375, 9150391, 9151407, 9152422, 9153438, 9154454,
>     9155470, 9156486, 9157502, 9158518, 9159534, 9160549, 9161565, 9162581,
>     9163597, 9164613, 9165629, 9166645, 9167660, 9168676, 9169692, 9170708 ;
> ...... (lines removed)
>  TOPOGRAPHY =
>   0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 51.99445,
>     124.9918, 103.0026, 170.9917, 191.9973, 183.0012, 214.9956, 215,
>     204.0016, 246.9934, 231.0025, 221.0016, 226.999, 224.0005, 249.9954,
>     211.0071, 232.9959, 242.9981, 224.0038, 231.9984, 222.0021, 240.9959,
>     271.9932, 265.0016, 284.9954, 286.9995, 289.9993, 293.999, 311.9955,
>     274.0097, 294.9946, 282.0034, 302.9944, 317.9959, 311.002, 314.9989,
>     330.9954, 338.9977,
>   0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 105.9893, 183.9907,
>     183.9983, 189.9981, 199.9982, 200.999, 215.9977, 224.9986, 217.0007,
>     264.993, 260.0003, 273.9973, 246.0043, 249.9992, 291.9925, 299.998,
>     300.9991, 277.004, 256.0034, 272.9964, 252.004, 246.001, 243.0005,
>     256.9968, 242.0032, 268.9941, 253.0037, 249.0013, 272.9945, 271.0006,
>     277.9984, 263.0042, 266.9991, 277.9973, 312.9904, 322.9971, 295.0079,
>     295.0002, 273.0067, 336.9814, 334.0009,
>   0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 96.98979, 189.9899,
>     180.001, 205.9969, 205.9997, 213.9988, 236.9966, 240.999, 255.9975,
> ...... etc etc
> The command I use to extract this topography variable is
> gdal_translate -of AAIGrid  NETCDF:"merapi.res.nc":TOPOGRAPHY
> merapi.topography.asc
> and the header of the resulting file is
> ncols        59
> nrows        64
> xllcorner    0.000000000000
> yllcorner    -64.000000000000
> cellsize     1.000000000000
> NODATA_value 9.9692099683868690468e+36
>       0      0      0      0      0      0      0      0      0      0
> 0      0      0      0      0      0      0      0      0      0      0
> 51.99444
> 9615478515625 124.9918365478515625 103.00257110595703125 170.99169921875
> 191.9973297119140625 183.001190185546875 214.99560546875    215
> 204.001617431640625
>  246.993438720703125 231.0025177001953125 ........
> I do not understand why the cellsize is 1.000000 when it should be in the
> order of 1000.
> Also, I do not understand why xllcorner and yllcorner aren't obtained as
> e.g. the minimum values of the x and y vectors.
> The version of gdal-bin is 1.5.2-3ubuntu1 and my platform is Ubuntu 9.04 (64
> bit).
> By the way, trying to contour directly from the NetCDF puts all the contours at the south pole. I suspect this is another manifestation of the origins being ignored.
> Can anyone help please?
> Cheers and thanks
> Ole Nielsen
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-translate-netcdf-to-aaigrid-wrong-cellsize-xllcorner-and-yllcorner-tp5073995p5073995.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
