[gdal-dev] NITF 2.1 GDAL 1.7.2 and FWTools 2.4.7 Translation Errors
Doug White doug.royce.white at gmail.com
Fri May 21 08:21:55 EDT 2010
Ok.  A little time away from the office seems has helped :-)
Have now translated 4 JPEG2000 compressed images to geotiff with any
problems.
The following patch for libecwj2-3.3 has fixed the problem. See...
http://trac.osgeo.org/gdal/wiki/ECW...
http://trac.osgeo.org/gdal/ticket/3366
I would very much like to see this flow through to FWTools for use on
Windows systems at work.
Doug.
On 05/21/2010 09:39 PM, David Boyd wrote:
> Doug:
>   I have seen similar issues on NITF with earlier versions of GDAL and
> frankly had hoped they were fixed in 1.7.2.
> Most of the issues I have seen were with the GDAL components
> incorporated into Geoserver.
> My images are all Compressed ADRG from NGA.
> I will be very interested to hear of any solution you uncover.
> Doug White wrote:
>> Hi,
>> I have been trying to translate a DigitalGlobe GeoEye-1 NITF image to
>> GeoTiff or JP2 with GDAL 1.7.2 compiled with JP2ECW on x86 Linux and
>> also with FWTools 2.4.7 (raises a unknown software exception).
>> gdalinfo will read the file successfully. I can display the file with
>> PCI Geomatics on a Windows platform.
>> However we consistently get a seg-fault on attempts to translate a
>> number of NITF images. It doesn't seem to matter what creation
>> options are used or what output format is chosen.
>> gdal_translate -of gtiff -co COMPRESS=LZW -sds test1.ntf out.tif
>> Input file size is 35840, 27648
>> 0...10...20...30...40...50...60...Segmentation fault
>> Output from gdalinfo is below along with supported formats.
>> Any assistance would be appreciate as I have potentially will have a
>> large number of similar images that must be transformed to either
>> GeoTiff or JP2 formats.
>> Regards,
>> Doug White.
>> gdalinfo test1.ntf
>> Driver: NITF/National Imagery Transmission Format
>> Files: test1.ntf
>> Size is 35840, 27648
>> Coordinate System is:
>> GEOGCS["WGS 84",
>>     DATUM["WGS_1984",
>>         SPHEROID["WGS 84",6378137,298.257223563,
>>             AUTHORITY["EPSG","7030"]],
>>         TOWGS84[0,0,0,0,0,0,0],
>>         AUTHORITY["EPSG","6326"]],
>>     PRIMEM["Greenwich",0,
>>         AUTHORITY["EPSG","8901"]],
>>     UNIT["degree",0.0174532925199433,
>>         AUTHORITY["EPSG","9108"]],
>>     AUTHORITY["EPSG","4326"]]
>> GeoTransform =
>>   151.8181220669296, 5.871164560022267e-06, -5.023651349735254e-09
>>   -20.99465038292781, 8.719551326766783e-07, -5.661655072079407e-06
>> Metadata:
>>   NITF_FHDR=NITF02.10
>>   NITF_CLEVEL=06
>>   NITF_STYPE=BF01
>>   NITF_OSTAID=DG
>>   NITF_FDT=20080105031559
>>   NITF_FTITLE=WV01_SENSOR:2008-01-04T23:56:28.358625Z
>>   NITF_FSCLAS=U
>>   NITF_FSCLSY=US
>>   NITF_FSCODE=
>>   NITF_FSCTLH=0
>>   NITF_FSREL=UNCLASSIFIED
>>   NITF_USE00A_ANGLE_TO_NORTH=270
>>   NITF_USE00A_MEAN_GSD=025.0
>>   NITF_USE00A_DYNAMIC_RANGE=02047
>>   NITF_USE00A_OBL_ANG=29.02
>>   NITF_STDIDC_ACQUISITION_DATE=20080104235628
>>   NITF_STDIDC_MISSION=WV01
>>   NITF_STDIDC_PASS=16
>>   NITF_STDIDC_OP_NUM=000
>>   NITF_STDIDC_START_SEGMENT=AA
>>   NITF_STDIDC_REPRO_NUM=00
>>   NITF_STDIDC_REPLAY_REGEN=000
>>   NITF_STDIDC_START_COLUMN=001
>>   NITF_STDIDC_START_ROW=00001
>>   NITF_STDIDC_END_SEGMENT=AA
>>   NITF_STDIDC_END_COLUMN=035
>>   NITF_STDIDC_END_ROW=00027
>>   NITF_STDIDC_COUNTRY=YY
>>   NITF_STDIDC_WAC=
>>   NITF_STDIDC_LOCATION=2059S15155E
>>   NITF_USE00A_ROLL_ANG=-19.90
>>   NITF_USE00A_N_REF=00
>>   NITF_USE00A_REV_NUM=01648
>>   NITF_USE00A_N_SEG=001
>>   NITF_USE00A_MAX_LP_SEG=027024
>>   NITF_USE00A_SUN_EL=+62.0
>>   NITF_USE00A_SUN_AZ=099.3
>>   NITF_FSDCTP=
>>   NITF_FSDCDT=
>>   NITF_FSDCXM=
>>   NITF_FSDG=
>>   NITF_FSDGDT=
>>   NITF_FSCLTX=
>>   NITF_FSCATP=
>>   NITF_FSCAUT=
>>   NITF_FSCRSN=
>>   NITF_FSSRDT=
>>   NITF_FSCTLN=
>>   NITF_FSCOP=00000
>>   NITF_FSCPYS=00000
>>   NITF_ENCRYP=0
>>   NITF_FBKGC=126,126,126
>>   NITF_ONAME=DigitalGlobe
>>   NITF_OPHONE=+1(800)496-1225
>>   NITF_IID1=P101B5EB00
>>   NITF_IDATIM=20080104235628
>>   NITF_TGTID=
>>   NITF_IID2=04JAN08WV011600008JAN04235628-P1BS-005692925010_02_P001
>>   NITF_ISCLAS=U
>>   NITF_ISCLSY=US
>>   NITF_ISCODE=
>>   NITF_ISCTLH=0
>>   NITF_ISREL=UNCLASSIFIED
>>   NITF_ISDCTP=
>>   NITF_ISDCDT=
>>   NITF_ISDCXM=
>>   NITF_ISDG=
>>   NITF_ISDGDT=
>>   NITF_ISCLTX=
>>   NITF_ISCATP=
>>   NITF_ISCAUT=
>>   NITF_ISCRSN=
>>   NITF_ISSRDT=
>>   NITF_ISCTLN=
>>   NITF_ISORCE=DigitalGlobe
>>   NITF_PVTYPE=INT
>>   NITF_IREP=MONO
>>   NITF_ICAT=VIS
>>   NITF_ABPP=11
>>   NITF_PJUST=R
>>   NITF_IMAGE_COMMENTS=The imagery and metadata data on this media is
>> the property of                  DigitalGlobe and is licensed for use
>> only. All use must be in                   accordance with the terms
>> of the license that accompanies the media.            If the license
>> is purchased under contract NMA 301 99 D003, use is              in
>> accordance with the license therein
>>   NITF_IC=C8
>>   NITF_IMODE=B
>>   NITF_IDLVL=1
>>   NITF_IALVL=0
>>   NITF_ILOC_ROW=0
>>   NITF_ILOC_COLUMN=0
>>   NITF_CCS_ROW=0
>>   NITF_CCS_COLUMN=0
>>   NITF_IMAG=1.0
>> Image Structure Metadata:
>>   COMPRESSION=JPEG2000
>> Subdatasets:
>>   SUBDATASET_1_NAME=NITF_IM:0:test1.ntf
>>   SUBDATASET_1_DESC=Image 1 of test1.ntf
>>   SUBDATASET_2_NAME=NITF_IM:1:test1.ntf
>>   SUBDATASET_2_DESC=Image 2 of test1.ntf
>> RPC Metadata:
>>   LINE_OFF=13513
>>   LINE_SCALE=13856
>>   SAMP_OFF=17568
>>   SAMP_SCALE=17880
>>   LONG_OFF=151.9233
>>   LONG_SCALE=0.1053
>>   LAT_OFF=-21.0572
>>   LAT_SCALE=0.094
>>   HEIGHT_OFF=56
>>   HEIGHT_SCALE=500
>>   LINE_NUM_COEFF=-0.0004377388 0.1957893 -1.171648 0.02476541
>> 0.0004988891 1.071111e-06 -7.723183e-05 -0.0001365399 0.0001504459
>> -3.044538e-07 -5.480692e-07 2.582038e-06 2.00101e-05 3.445864e-06
>> -1.734241e-05 -7.362311e-05 -2.064705e-05 3.295859e-07 3.97851e-06
>> 2.958957e-07
>>   LINE_DEN_COEFF=1 0.0006958351 -0.0004343016 -7.94123e-05
>> 3.205817e-05 -6.129374e-07 2.904883e-06 1.144677e-05 -6.601517e-05
>> 1.76217e-05 2.432827e-07 1.147129e-07 3.2925e-07 3.846231e-08
>> -8.681516e-07 9.004578e-06 -1.561498e-07 0 -1.282879e-06 3.197183e-07
>>   SAMP_NUM_COEFF=-0.005897845 0.9845455 -0.0008736188 -0.01633278
>> -0.0005572224 0.0004192778 -0.0001797468 0.006762 3.550668e-05
>> -2.729457e-06 -2.47284e-06 2.339311e-05 -1.283381e-05 -5.962048e-06
>> 4.604063e-05 8.796591e-06 1.358451e-08 5.049965e-06 -1.806894e-08 0
>>   SAMP_DEN_COEFF=1 -0.0008445728 0.000539573 -0.0005092088
>> -3.422971e-05 -3.243685e-06 1.062892e-06 5.948981e-06 1.065874e-05
>> -6.439563e-06 -5.457996e-08 0 -3.445098e-07 3.646394e-08
>> -7.223879e-07 1.128396e-06 0 -3.12891e-08 -4.239271e-08 0
>>   MIN_LONG=151.87065
>>   MAX_LONG=151.97595
>>   MIN_LAT=-21.1042
>>   MAX_LAT=-21.0102
>> Corner Coordinates:
>> Upper Left  ( 151.8181221, -20.9946504) (151d49'5.24"E, 20d59'40.74"S)
>> Lower Left  ( 151.8179832, -21.1511838) (151d49'4.74"E, 21d 9'4.26"S)
>> Upper Right ( 152.0285446, -20.9633995) (152d 1'42.76"E, 20d57'48.24"S)
>> Lower Right ( 152.0284057, -21.1199330) (152d 1'42.26"E, 21d 7'11.76"S)
>> Center      ( 151.9232639, -21.0572917) (151d55'23.75"E, 21d 3'26.25"S)
>> Band 1 Block=35840x1 Type=UInt16, ColorInterp=Gray
>>   Overviews: arbitrary
>> gdal_translate --formats
>> Supported Formats:
>>   VRT (rw+): Virtual Raster
>>   GTiff (rw+v): GeoTIFF
>>   NITF (rw+v): National Imagery Transmission Format
>>   RPFTOC (ro): Raster Product Format TOC format
>>   HFA (rw+v): Erdas Imagine Images (.img)
>>   SAR_CEOS (ro): CEOS SAR Image
>>   CEOS (ro): CEOS Image
>>   JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
>>   GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
>>   ELAS (rw+): ELAS
>>   AIG (ro): Arc/Info Binary Grid
>>   AAIGrid (rwv): Arc/Info ASCII Grid
>>   SDTS (ro): SDTS Raster
>>   OGDI (ro): OGDI Bridge
>>   DTED (rwv): DTED Elevation Raster
>>   PNG (rwv): Portable Network Graphics
>>   JPEG (rwv): JPEG JFIF
>>   MEM (rw+): In Memory Raster
>>   JDEM (ro): Japanese DEM (.mem)
>>   GIF (rwv): Graphics Interchange Format (.gif)
>>   BIGGIF (rov): Graphics Interchange Format (.gif)
>>   ESAT (ro): Envisat Image Format
>>   FITS (rw+): Flexible Image Transport System
>>   BSB (ro): Maptech BSB Nautical Charts
>>   XPM (rw): X11 PixMap Format
>>   BMP (rw+v): MS Windows Device Independent Bitmap
>>   DIMAP (ro): SPOT DIMAP
>>   AirSAR (ro): AirSAR Polarimetric Image
>>   RS2 (ro): RadarSat 2 XML Product
>>   PCIDSK (rw+v): PCIDSK Database File
>>   PCRaster (rw): PCRaster Raster File
>>   ILWIS (rw+v): ILWIS Raster Map
>>   SGI (rw+): SGI Image File Format 1.0
>>   SRTMHGT (rwv): SRTMHGT File Format
>>   Leveller (rw+): Leveller heightfield
>>   Terragen (rw+): Terragen heightfield
>>   GMT (rw): GMT NetCDF Grid Format
>>   netCDF (rw): Network Common Data Format
>>   HDF4 (ro): Hierarchical Data Format Release 4
>>   HDF4Image (rw+): HDF4 Dataset
>>   ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
>>   ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
>>   PDS (ro): NASA Planetary Data System
>>   TIL (ro): EarthWatch .TIL
>>   ERS (rw+): ERMapper .ers Labelled
>>   ECW (rw): ERMapper Compressed Wavelets
>>   JP2ECW (rw+): ERMapper JPEG2000
>>   JPEG2000 (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1)
>>   L1B (ro): NOAA Polar Orbiter Level 1b Data Set
>>   FIT (rw): FIT Image
>>   GRIB (ro): GRIdded Binary (.grb)
>>   MrSID (ro): Multi-resolution Seamless Image Database (MrSID)
>>   RMF (rw+): Raster Matrix Format
>>   WCS (ro): OGC Web Coverage Service
>>   WMS (ro): OGC Web Map Service
>>   MSGN (ro): EUMETSAT Archive native (.nat)
>>   RST (rw+): Idrisi Raster A.1
>>   INGR (rw+): Intergraph Raster
>>   GSAG (rw): Golden Software ASCII Grid (.grd)
>>   GSBG (rw+): Golden Software Binary Grid (.grd)
>>   GS7BG (ro): Golden Software 7 Binary Grid (.grd)
>>   COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
>>   TSX (ro): TerraSAR-X Product
>>   COASP (ro): DRDC COASP SAR Processor Raster
>>   R (rwv): R Object Data Store
>>   PNM (rw+): Portable Pixmap Format (netpbm)
>>   DOQ1 (ro): USGS DOQ (Old Style)
>>   DOQ2 (ro): USGS DOQ (New Style)
>>   ENVI (rw+v): ENVI .hdr Labelled
>>   EHdr (rw+v): ESRI .hdr Labelled
>>   GenBin (ro): Generic Binary (.hdr Labelled)
>>   PAux (rw+): PCI .aux Labelled
>>   MFF (rw+): Vexcel MFF Raster
>>   MFF2 (rw+): Vexcel MFF2 (HKV) Raster
>>   FujiBAS (ro): Fuji BAS Scanner Image
>>   GSC (ro): GSC Geogrid
>>   FAST (ro): EOSAT FAST Format
>>   BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
>>   LAN (ro): Erdas .LAN/.GIS
>>   CPG (ro): Convair PolGASP
>>   IDA (rw+): Image Data and Analysis
>>   NDF (ro): NLAPS Data Format
>>   EIR (ro): Erdas Imagine Raw
>>   DIPEx (ro): DIPEx
>>   LCP (rov): FARSITE v.4 Landscape File (.lcp)
>>   RIK (ro): Swedish Grid RIK (.rik)
>>   USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
>>   GXF (ro): GeoSoft Grid Exchange Format
>>   HTTP (ro): HTTP Fetching Wrapper
>>   BAG (ro): Bathymetry Attributed Grid
>>   HDF5 (ro): Hierarchical Data Format Release 5
>>   HDF5Image (ro): HDF5 Dataset
>>   NWT_GRD (ro): Northwood Numeric Grid Format .grd/.tab
>>   NWT_GRC (ro): Northwood Classified Grid Format .grc/.tab
>>   ADRG (rw+v): ARC Digitized Raster Graphics
>>   SRP (rov): Standard Raster Product (ASRP/USRP)
>>   BLX (rw): Magellan topo (.blx)
>>   Rasterlite (rw): Rasterlite
>>   WKTRaster (ro): PostGIS WKT Raster driver
>>   SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
