[gdal-dev] Re: gdal_retile and nodata
christian.mueller at nvoe.at christian.mueller at nvoe.at
Fri May 21 09:50:35 EDT 2010
AFAIK at the time I did the gdal_retile there was no concept of aux.xml files.
Anyways, the utility does no image operation itself, we will see on Monday.
Quoting acangi <aca at ngi.be>:
> After removing the GDAL_PAM_ENABLED=NO, I made a
> gdal_translate -a_nodata 0
> on the files, this generated the aux.xml files, and gdalinfo shows now the
> nodata values :
> Band 1 Block=4000x16 Type=Byte, ColorInterp=Red
>   NoData Value=0
> Band 2 Block=4000x16 Type=Byte, ColorInterp=Green
>   NoData Value=0
> Band 3 Block=4000x16 Type=Byte, ColorInterp=Blue
>   NoData Value=0
> gdal_retile is currently running, but it doesn't produce aux.xml files.
> gdalinfo doesn't show any nodata value on the files generated by
> gdal_retile. So I guess when the next level will start computing, the same
> problem will reproduce. I should see the result monday.
> Alain
> http://osgeo-org.1803224.n2.nabble.com/gdal-retile-and-nodata-tp5079895p5084204.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
