[gdal-dev] Re: Modify virtual file attributes
Luca Fasano lucafasano at interfree.it
Wed May 26 11:00:56 EDT 2010
I noticed that in current trunk version SetScale and SetOffset methods are
present for the API of gdal.Band in Python bindings.
As reported in ticket num. 3587:
With [19412] SetScale and SetOffset methods are added.
When SetUnitType method will be added too, this ticket could be considered
as solved.
If also SetUnitType method will be added, a backport should be wonderful :)
Best regards
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Modify-virtual-file-attributes-tp5074120p5103992.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
