[gdal-dev] Using GDAL with KOMPSAT-2 images
Luis Lisboa luislisboa1975 at gmail.com
Wed May 26 11:33:25 EDT 2010
Greetings
While I was importing to GRASS some KOMPSAT-2 images I got a few warnings.
Then, I decided to do some GDALINFO over those Kompsat-2 images and I got
the following warnings:
Warning 1: TIFFFetchNormalTag:ASCII value for tag "DocumentName" does not
end in null byte
Warning 1: TIFFFetchNormalTag:ASCII value for tag "ImageDescription" does
not end in null byte
Warning 1: TIFFFetchNormalTag:ASCII value for tag "Artist" does not end in
null byte
Warning 1: TIFFFetchNormalTag:ASCII value for tag "HostComputer" does not
end in null byte
And only after this I got the gdalinfo response:
Driver: GTiff/GeoTIFF
Files: MSC_090905125514_16582_25480940M3P07N_1G.tif
Size is 4551, 4663
Coordinate System is:
PROJCS["WGS 84 / UTM zone 24S",
    GEOGCS["WGS_1984",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.2572235604902,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT[,0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-39],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",10000000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","32724"]]
Origin = (602410.721905449754559,9118774.368212059140205)
Pixel Size = (4.000000000000000,-4.000000000000000)
Metadata:
  TIFFTAG_DOCUMENTNAME=MSC_090905125514_16582_25480940M3P07N_1G.tif
  TIFFTAG_IMAGEDESCRIPTION=GeoTIFF v1.0 : KOMPSAT2 MSC Image Level 1G
Product Level 1G
  TIFFTAG_DATETIME=2009:09:05 12:56:16
  TIFFTAG_ARTIST=Received IRPE NULL Location 0.000000/0.000000 Processing
TLS Location 43.600000/1.440000
  TIFFTAG_HOSTCOMPUTER=Producer background SW version CAP 1.0.091126.01
  TIFFTAG_XRESOLUTION=1
  TIFFTAG_YRESOLUTION=1
  TIFFTAG_MINSAMPLEVALUE=0
  TIFFTAG_MAXSAMPLEVALUE=1100
  TIFFTAG_RESOLUTIONUNIT=1 (unitless)
  AREA_OR_POINT=Point
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  602410.722, 9118774.368) ( 38d 4'14.81"W,  7d58'16.21"S)
Lower Left  (  602410.722, 9100122.368) ( 38d 4'13.43"W,  8d 8'23.51"S)
Upper Right (  620614.722, 9118774.368) ( 37d54'20.26"W,  7d58'14.75"S)
Lower Right (  620614.722, 9100122.368) ( 37d54'18.62"W,  8d 8'22.02"S)
Center      (  611512.722, 9109448.368) ( 37d59'16.78"W,  8d 3'19.15"S)
Band 1 Block=4551x1 Type=UInt16, ColorInterp=Gray
  Metadata:
    LAYER_TYPE=athematic
What this warnings refer to? is this a critical issue?
Thanks
Best regards,
Luis
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100526/e4a6187e/attachment.html
