[gdal-dev] Re: Gdal.Allregister Error
radioheadCDA chrisaustin2009 at gmail.com
Wed May 26 14:15:59 EDT 2010
So I found the inner exception for the All register problem and it says it
can't load the dll "gdal_wrap" but I have put an environment variable
pointing to the folder its but it still shows up the exception. Is there any
other reason why it would load the "gdal_wrap" dll?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-Allregister-Error-tp5104079p5105015.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
