[gdal-dev] Re: Handling CPG (encoding) file
Even Rouault even.rouault at mines-paris.org
Wed May 26 14:31:00 EDT 2010
> > For the write part, a OGRSFDriver::GetSupportedEncodings() and
> > OGRLayer::SetEncoding() could make sense (for the later, if it must be
> > exposed at the datasource or layer level is an open point and a slight
> > difference between yours and Gaige's approach)
> Is there a need for a per-layer approach to this?   I've yet to see a
> format that allowed different encodings in different layers.   Although,
> thinking about it, it might be a problem using some of the virtual data
> sets, since they hide some of this.
Actually, I'm not confident that a standalone SetEncoding() method is
appropriate. This should rather be an extra parameter (or a "stantardized"
creation option) of CreateDataSource() , as drivers will often need that
information at the very beginning to write the appropriate header (for
example the encoding of a XML file) and you cannot sanely change encoding in
the middle of writing a file...
Also, when you create a non UTF-8 datasource,
- is the data passed to the driver already encoded in the target encoding (a)
- or is it in UTF-8 (b) and the driver is responsible to convert it to the
target encoding.
Approach (a) gives strong predictibility of which bytes go to the file and
enable the user to control how he wants the data to be degraded. But the
downside of it is is that it would lead to a weird behaviour for read/write
datasources. When you read, you'd get data in UTF-8 (AFAIK all encodings can
be losslessly transcoded to UTF-8. Correct me if I'm wrong), but when you
write you pass it in encoding XXXX ...
