[gdal-dev] GDAL installation on Linux (CentOS 64bit)
Mostafa Jabarouti Moghaddam zavata.afnan at gmail.com
Wed May 26 16:20:08 EDT 2010
I downloaded all packages (
http://download.opensuse.org/repositories/Application:/Geo/CentOS_5/x86_64/)
for CentOS 5.
When i try to install netcdf-4.0.1-7.1.x86_64.rpm, I get this error:
root at localhost gdal17_64bit]# rpm -i netcdf-4.0.1-7.1.x86_64.rpm
warning: netcdf-4.0.1-7.1.x86_64.rpm: Header V3 DSA signature: NOKEY, key ID
9591c39b
error: Failed dependencies:
        libnetcdf.so.4()(64bit) is needed by netcdf-4.0.1-7.1.x86_64
On the other hand, when i try to install libnetcdf4-4.0.1-7.1.x86_64.rpm, I
get this error:
[root at localhost gdal17_64bit]# rpm -i libnetcdf4-4.0.1-7.1.x86_64.rpm
warning: libnetcdf4-4.0.1-7.1.x86_64.rpm: Header V3 DSA signature: NOKEY,
key ID 9591c39b
        netcdf = 4.0.1 is needed by libnetcdf4-4.0.1-7.1.x86_64
So how can i install netcdf properly?
Is there anyone has this problem?
Best Regards,
MJM
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100526/65713c9d/attachment.html
