[gdal-dev] Converting coordinates/Projection
Thu May 27 08:46:17 EDT 2010
Gilbert Ferrara wrote:
> Hi there
> I have a few satellite images in Latlon WGS84 and I need to convert it
> to UTM (a specific Zone). What GDAL tool shall I use? GDAL_translate or
> GDALWARP?
Gilbert,
To reproject an image gdalwarp is the appropriate tool.  If the image is
properly georeferenced already, it may be sufficient to do something like:
   gdalwarp -t_srs "+proj=utm +zone=11 +datum=WGS84" latlong.tif utm.tif
Best regards,
