[gdal-dev] S-57 Driver WRONG Geometry
Bogdan Grama bogdan.grama at soft-union.ro
Fri May 28 03:13:31 EDT 2010
<http://nestgroup.wordpress.com/2008/04/03/nepalese-cultural-programme-2008-trondheim-norway-by-nest/>Thank
You all for your great effort!!!
Bogdan
On 5/27/2010 6:19 PM, Frank Warmerdam wrote:
> Bogdan Grama wrote:
>> Dear Frank
>> Please find in the archive (http://www.wgs.ro/gdal/0_w.zip):
>> -the ENC
>> -GDAL Interpretation
>> -correct  Interpretation
>> The assembled geometry is not according with specifications. Each
>> referenced edge starts and ends with a ConnectedNode. Not all the
>> Connected nodes are present in the feature geometry dump.
>> This is not all. If the file is rendered with Sevencs
>> (http://www.sevencs.com/service-products/download) and few others
>> viewers the rendering is correct.
>> For GDAL, ESRI FME, Caris the geometry is not correct.
> Folks,
> I have determined this is the same as the previously reported:
>   http://trac.osgeo.org/gdal/ticket/2147
> for which I neglected to apply the patch.  I have revised the patch
> and applied it in trunk and 1.7 branch.
> Best regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100528/a9fcf379/attachment.html
