[gdal-dev] status of the OGR Norwegian SOSI support
Tamas Szekeres szekerest at gmail.com
Thu Nov 4 11:49:21 EDT 2010
I need to clarify the things a little bit. Actually the compiled binaries
for the FYBA library are downloadable from here:
http://www.statkart.no/nor/SOSI/Program/
However this version depends on the Visual Studio 2005 Win32 CRT libraries
(msvcr80.dll) which would provide at the most to include this in
release-1400-gdal-mapserver.zip<http://vbkto.dyndns.org/sdk/release-1400-gdal-mapserver.zip>
but in my preference all of the packages should support each drivers for
gdal equally well. I would also continue to avoid mixed CRT dependencies in
the packages which is unsupported by Microsoft, and therefore I would
require either of the following options to be provided by the author of the
library:
1. Compiled binaries for all platforms x32/x64 from MSVC2003 up to MSVC2010
2. The source files which can be compiled by myself with these compilers
Currently none of the options above are available as far as I know.
Further issue may be due to my limited knowledge about the licensing terms
of this library, I can see a .txt file in the package but it's not in that
language which I can easily understand.
Best regards,
Tamas
2010/11/4 lucvanlinden <luc.vanlinden at gmail.com>
> Does anyone know the status of the OGR Norwegian SOSI support?
> Tamas Szekeres, confirmed it is not being included in the daily built
> binaries as the SOSI support depends on a missing FYBA binaries, which
> seems
> to be the last reference in this ticket:
> http://trac.osgeo.org/gdal/ticket/3638#comment:1
> tx
> Luc
> http://osgeo-org.1803224.n2.nabble.com/status-of-the-OGR-Norwegian-SOSI-support-tp5705081p5705081.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101104/5760285e/attachment.html
