[gdal-dev] gdalinfo crashes or reports an error when reading a FITS
	file
    Eric Davies
    eric at barrodale.com
    Mon Nov  8 16:31:06 EST 2010
I've been trying to use the gdalinfo application to examine a number
of FITS files that I've grabbed off the net. I've run into problems
with both the precompiled/linked version of gdalinfo that comes with
FWTOOLS.2.0.6, and with a copy I built myself from GDAL 1.7.2 source
code and the cfitsio library. I'm running Linux (Fedora Core 13,
Kernal 2.6) on a 32 bit Intel platform. It's not that I'm interested
so much in the output of gdalinfo, but I wanted to verify that the
underlying GDAL library could handle FITS before using it in my own
application.
Most FITS files I tried caused gdalinfo to die with a segmentation
fault. For example, the following files caused segmentation faults:
http://fits.gsfc.nasa.gov/nrao_data/tests/ftt4b/file013.fits
http://fits.gsfc.nasa.gov/nrao_data/samples/wcs/m82opt.fits
The remaining files I tried caused more graceful failures,
represented by the message below.
ERROR 1: FITS file /opt/data/fits/ngc6503.fits does not have 2 or 3
dimensions.
gdalinfo failed - unable to open '/opt/data/fits/ngc6503.fits'.
File from http://fits.gsfc.nasa.gov/nrao_data/samples/cubes/ngc6503.fits
I was able to view these FITS file using SAOImage DS9. indicating
that the files were not corrupt.
Has anybody tested GDAL against FITS files recently?
Thank you,
Eric.
Eric Davies, M.Sc.
Senior Programmer Analyst
Barrodale Computing Services Ltd.
1095 McKenzie Ave., Suite 418
Victoria BC V8P 2L5
Canada
Tel: (250) 704-4428
Web: http://www.barrodale.com
Email: eric at barrodale.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101108/1c11fffe/attachment.html
