[gdal-dev] Motion: Promote GDAL/OGR 1.7.3RC2 to final release
Tue Nov 9 10:32:22 EST 2010
Peter Hopfgartner wrote:
> I wrapped a quick rpm package, installed the rpms and tried to run autotest. The tests comes to this point:
> Running tests from gcore/mask.py
>   TEST: mask_1 ... success
>   TEST: mask_2 ... success
>   TEST: mask_3 ... success
>   TEST: mask_4 ... success
>   TEST: mask_5 ... ERROR 1: ZIPDecode:tmp/mask_4.pnm.msk: Decoding error at scanline 0, incorrect header check
> ERROR 1: TIFFReadEncodedTile() failed.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 0
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
> Segmentation fault
> The platform id CentOS 5.5/x86_64, with some packages from EPEL and elgis.
Peter,
What libtiff is this using?  Internal?  External libtiff4?  libtiff3.x?
The test suite pushes many boundary cases that only work with the latest
libtiff4 code particularly because GDAL tends to be the client that
pushes the boundaries of libtiff.
Best regards,
