[gdal-dev] python: possible to get Dataset from Band
Even Rouault even.rouault at mines-paris.org
Tue Nov 9 17:48:14 EST 2010
Le mardi 09 novembre 2010 23:34:35, Gregory, Matthew a écrit :
> Hi all,
> An easy question and apologies if it's been asked before.
> Is there a way to get the owning gdal.Dataset from a gdal.Band within
> Python?  I'm not seeing GetDataset() as in C/C++ within the Python
> bindings.
No, there's no direct way of doing it with an API call. But as you can only
get a Band from a Dataset, you can easily do something like :
band = ds.GetRasterBand(xxx)
band.ds = ds
and then use band.ds to get access to the dataset...
