[gdal-dev] getting a new gcs.csv
Andrea Peri
aperi2007 at gmail.com
Thu Nov 11 02:07:41 EST 2010
Hi Anders,
after copy all file cvs in the same folder where i execute ogr2ogr.exe
the error disappeared. Without need to set the gdal_data variable. :)
Before I copied only the two file gcs.cvs and pcs.cvs.
I think that variable is needed if the cvs files there are in other folder
than the org2ogr folder.
regards,
Andrea.
2010/11/10 Anders Moe <anders.moe at geocap.no>
> Andrea
> I've had my share of problems finding the *.cvs files too, but maybe you
> could try :
> 1) Executing from the location of the ogr2ogr.exe utility
> 2) Having the *.cvs files in that directory
> 3) Having the GDAL_DATA environment variable set to the same directory.
> Cheers,
> Anders
> On Tue, Nov 9, 2010 at 6:57 PM, Andrea Peri 2007 <aperi2007 at gmail.com>wrote:
>> Frank,
>> thx for link.
>> I take the last gcs.csv and pcs.csv.
>> I verify that in the new pcs.csv there is EPSG:3003 (it is projected)
>> but even now ogr2ogr.exe still report me
>> the epsg pcs/gcs code 3003 not found.
>> seem that ogr2ogr is not using the pcs.csv file .
>> Thx,
>> Andrea.
>> Il 09/11/2010 18:13, Frank Warmerdam ha scritto:
>> Andrea Peri 2007 wrote:
>>>> Hi,
>>>> I'm trying to use the ogr2ogr.exe compiled with VC++ .
>>>> running ogr2ogr it give me this message:
>>>> ERROR 4: Unable to open EPSG support file gcs.csv
>>>> so I retrieve a gcs.csv file from FWTools2.4.7 and copy it in the same
>>>> folder of ogr2ogr.
>>>> after this copy.
>>>> The new message from ogr2ogr is this:
>>>> "error 6: epsg pcs/gcs code 3003 not found in EPSG support files. Is
>>>> this a valid EPSG"
>>>> I check to the www.epsg.org that EPSG:3003 is a valid epsg coordinate
>>>> system.
>>>> So I think perhaps the gcs.csv file of fwtool is old.
>>>> There is available a new version of gcs.csv ?
>>> Andrea,
>>> The latest gcs.csv and pcs.csv can be found at:
>>> http://svn.osgeo.org/gdal/trunk/gdal/data
>>> They should work fine with older GDAL's.
>>> Best regards,
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> ________________________________________________________
> Anders Moe
> Managing Director
> Geocap
> w: +47 22 95 56 63
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101111/d41581e7/attachment.html
