[gdal-dev] Something is broken on Win install
Joaquim Luis jluis at ualg.pt
Sat Nov 13 13:25:51 EST 2010
On 13-11-2010 18:02, Frank Warmerdam wrote:
> Joaquim Luis wrote:
>>         cd ..\apps
>>         nmake /nologo /f makefile.vc install
>>         copy *.exe ..\WIN64\bin
>> gdaladdo.exe
>> The system cannot find the path specified.
>>         0 file(s) copied.
>> NMAKE : fatal error U1077: 'copy' : return code '0x1'
>> Stop.
>> The problem seams to be that it's trying to put things in
>> ..\WIN64\bin
>> which I never told it to do. My nmake.opt has
>> !IFDEF WIN64
>> GDAL_HOME = "C:\programs\GDALtrunk\gdal\compileds\VC10_64"
>> !ELSE
>> !IF $(MSVC_VER) >= 1600
>> GDAL_HOME = "C:\programs\GDALtrunk\gdal\compileds\VC10_32"
> Joaquim,
> I don't know why this is happening in your case. I tried a clean
> build and install on windows (32 bit) from trunk and had no problem.
> Best regards,
Frank,
I found it. I had just rebuild GMT on the same command window and it
looks that I had a variablr name contamination from the GMT build.
Starting with a new command window worked fine again.
Sorry for the noise.
Joaquim
