[gdal-dev] OGDI version
Mon Nov 15 11:49:35 EST 2010
Malm Paul wrote:
> How can I find out of which version of OGDI (vector, vpf) that is used
> with GDAL 1.7.2.
Paul,
GDAL does not include a copy of the OGDI library, and can be built against
several different versions.  So the answer will be specific to the build
you are using and you need to ask whoever built it.
Best regards,
