[gdal-dev] gdal and Solaris 10
sophia parafina creta.kano at gmail.com
Tue Nov 16 13:38:29 EST 2010
see http://trac.osgeo.org/gdal/ticket/3670
On Tue, Nov 16, 2010 at 9:53 AM, Corrado, George P. <
George.Corrado at gd-ais.com> wrote:
> Ok, I've installed gcc and its dependences, but I can't figure out why I'm
> getting this error when I run make.  Any ideas?
> make
> (cd port; make)
> make[1]: Entering directory `/export/gdal/gdal-1.7.3/port'
> /bin/sh /export/gdal/gdal-1.7.3/libtool --mode=compile --tag=CXX g++ -g -O2
>  -Wall  -DOGR_ENABLED -I/export/gdal/gdal-1.7.3/port          -DHAVE_LIBZ -c
> -o cpl_conv.lo cpl_conv.cpp
> /export/gdal/gdal-1.7.3/libtool: syntax error at line 659:
> `func_arith_result=$' unexpected
> make[1]: *** [cpl_conv.lo] Error 2
> make[1]: Leaving directory `/export/gdal/gdal-1.7.3/port'
> make: *** [port-target] Error 2
> Thanks,
> George
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] On Behalf Of Corrado, George P.
> Sent: Tuesday, November 16, 2010 8:44 AM
> To: gdal-dev at lists.osgeo.org
> Subject: RE: [gdal-dev] gdal and Solaris 10
> Ok cool, yeah, I'm trying to build it on a Solaris 10 Sparc system now.  I
> believe I'm using the Sun compilers as well.  I'm guessing I can't just run
> the commands below without configuring a bunch of stuff?
> % cd gdal
> % ./configure
> % make
> % su
> Password: ********
> # make install
> # exit
> Thanks,
> George
> From: Peter J Halls [mailto:P.Halls at york.ac.uk]
> Sent: Tuesday, November 16, 2010 8:36 AM
> To: Corrado, George P.
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] gdal and Solaris 10
> George,
> Corrado, George P. wrote:
> > Does anyone know if gdal will work on Solaris 10, if so which of the
> prebuilt binaries can I use?  Or do I have to build  the binaries from
> scratch?
> Build from scratch is best.  I've been running it on Solaris 10 / Sparc for
> years without problems.  I do not know whether there may be any issues on
> Solaris 10 / Intel, but I do dot see why there should be any.
> My version is built using the Sun compilers.
> Best wishes,
> Peter
> > Thanks,
> > George
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Peter J Halls, GIS Advisor, University of York
> Telephone: 01904 323806     Fax: 01904 323740
> Snail mail: IT Services, University of York, Heslington, York YO10 5DD
> This message has the status of a private and personal communication
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101116/4875a403/attachment.html
