[gdal-dev] GDAL (via Java bindings) and ECW
Ronan Crowley ronan.crowley at gmail.com
Thu Nov 18 10:24:41 EST 2010
Hi All,
I'm using GDAL (via Java) to view an ECW file.
It generally works fine, however I'm having serious memory issues.
I have a 6MB ECW file, that when I try to view in its entirety I get
OutOfMemory errors.
The code I'm using to extract the image is pretty much the code from the
GDALtest.java file in the swig sub-project.
What I'm wodering, is if there is any way to get the number of pyramid
levels inside the image and grab the top-most pyramid level image ?
Thanks,
Ronan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101118/a9d47e2b/attachment.html
