[gdal-dev] problem with gdalwarp in 1.7
geographika
geographika at gmail.com
Fri Nov 19 05:22:43 EST 2010
I have upgraded from GDAL 1.6 (32bit Windows) to 1.7 (64 bit Windows)
and the following command no longer works:
C:\mapserver\bin\gdal\apps\gdalwarp C:\Data\Rasters\MiscSuit.tif
C:\RasterClips\mytest.tif -cutline c:\RasterClips\hello.json -te
118008.672141 177232.164284 138695.761666 206164.398565 -dstnodata -9999
I get the following message in the command prompt:
Creating output file that is 414P x 579L.
Processing input file C:\Data\Rasters\MiscSuit.tif.
for band 1, destination nodata value has been clamped to 0, the
original value being out of range.
ERROR 1: Failed to parse CUTLINE geometry wkt.
The CUTLINE is valid GeoJSON (but would clearly be invalid WKT) and
produces the correct results in 1.6.
The ogr formats lists GeoJSON as read/write.
I am using 64-bit builds of GDAL taken from http://vbkto.dyndns.org/sdk/
I have also tried using the development version of GDAL 1.8dev but get
the same message. If I do not use a CUTLINE the gdalwarp completes
successfully but the new image does not contain any data from my
original image (all cells are NoData).
Any help on this is much appreciated.
Regards,
Seth G.
http://geographika.co.uk
