[gdal-dev] Unable to load CIB datasets with GDAL
Fri Nov 19 14:00:45 EST 2010
morabit wrote:
> Hi All,
>   In our project we are using GDAL 1.7.2 to load map data in various formats
> as CADRG, DTED, CIB, etc.
> All it's working fine but we have a big problem with the CIB format.
> For this type of datasets, the GDALOpen function fails with the following
> error message:
> 'For <frameFileName>, assert 'geoTransf[GEOTRSFRM_ROTATION_PARAM1] == 0 &&
> geoTransf[GEOTRSFRM_ROTATION_PARAM2] == 0' failed.'
> We checked the source code and discovered that this was due to a series of
> assert failures
> in file rpftocdataset.cpp, lines 733, 740.
> We tried to comment out this asserts, but now the same function fails with
> the following error message:
> 'Ignoring NITF RPF Location table since it seems to be corrupt.'
> We are pretty sure that our datasets are not corrupted, as the same datasets
> are loaded
> without any problems by Global Mapper v12.00 and FalconView 4.3.0.
> The gdalinfo tool seems to handle these files with no problems but if we use
> it
> with the -mm option the following errors are reported:
> Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
>   ERROR 6: File lacks VQ LUTs, unable to decode image
> ERROR 1: IReadBlock failed at X offset 0, Y offset 0
> ERROR 6: File lacks VQ LUTs, unable to decode imagery
> ERROR 1: IReadBlock failed at X offset 1, Y offset 0
> ERROR 1: Failed to compute min/max, no valid pixels found in sampling.
Bruno,
Could you create a ticket in the GDAL trac for this issue?  When I run
the nitfdump utility against the .I42 file I get messages like:
ERROR 1: Cannot read RPFIMG TRE. Not enough bytes : remaining 1350, expected 1400
Do you see anything similar when accessing the full file?
This might be an issue easier for Even to review as he wrote the RPFTOC
driver.
Best regards,
