[gdal-dev] Re: error compiling gdal 1.6.3 in rhel 5 64bits
javiricca fjricca at gmail.com
Sat Nov 20 09:16:51 EST 2010
Could be a problem of swap version?
I find this
2010/11/18 Frank Warmerdam [via OSGeo.org] <
ml-node+5752145-975518027-113114 at n2.nabble.com<ml-node%2B5752145-975518027-113114 at n2.nabble.com>
> javiricca wrote:
> > Hello,
> > I'll trying to compile gdal in rhel 5 64 bits and I've getting some
> errors.
>  > gdal_wrap.cpp:1067: error: ‘zend_property_reference’ no se declaró en
> este
> ámbito
> > How can I solve this problem? Is possible to solve it with another
> version
> > of gdal or installing other libraries.
> > Thanks in advance
> Javiricca,
> Presumably this is a problem with the php bindings.  The php bindings are
> not maintained at this time and it is unclear to what extent they work or
> don't work.  So my suggestion is that they should not be part of your
> packaging effort unless you know they work in a useful way.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, [hidden email]<http://user/SendEmail.jtp?type=node&node=5752145&i=0>
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5752145&i=1>
>  View message @
> http://osgeo-org.1803224.n2.nabble.com/error-compiling-gdal-1-6-3-in-rhel-5-64bits-tp5750785p5752145.html
> To unsubscribe from error compiling gdal 1.6.3 in rhel 5 64bits, click
> here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5750785&code=ZmpyaWNjYUBnbWFpbC5jb218NTc1MDc4NXwxODk1MjMyMDA1>.
FJRicca
http://picasaweb.google.es/fjricca
http://perdonaqueseasoez.com/
View this message in context: http://osgeo-org.1803224.n2.nabble.com/error-compiling-gdal-1-6-3-in-rhel-5-64bits-tp5750785p5758160.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101120/a13d614b/attachment-0001.html
