[gdal-dev] Re: UnsatisfiedLinkError with gdal14
Tamas Szekeres szekerest at gmail.com
Sun Nov 21 08:19:21 EST 2010
2010/11/21 MarvinCO <marvin.offiah at googlemail.com>
> Which are the common DLL search locations? Eclipse doesn't give me any clue
> about how its starts the JVM, and which additional locations it may ask the
> JVM to search automatically. Process monitor also doesn't really give me
> any
> clue, it shows me mainly files from the System32 folder, which should
> already be part of the PATH.
For further info refer to the following document:
http://msdn.microsoft.com/en-us/library/ms682586%28VS.85%29.aspx
> What do you mean by setting the PATH environment of the javaw process? Is
> there any VM argument to set that?
I admit I'm not an expert in java. With C# we could probably use
Environment.SetEnvironmentVariable for this purpose.
Have you managed to use Process Monitor I have mentioned before?
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101121/3346b86c/attachment.html
