[gdal-dev] problem with gdalwarp in 1.7
Chaitanya kumar CH
chaitanya.ch at gmail.com
Sun Nov 21 09:38:10 EST 2010
Seth,
You can obtain the WKT of the geometries in a vector data source by using
ogrinfo with the -al option.
(http://www.gdal.org/ogrinfo.html)
On Sun, Nov 21, 2010 at 6:20 PM, geographika <geographika at gmail.com> wrote:
> On 19/11/2010 18:04, Frank Warmerdam wrote:
>> geographika wrote:
>>> Hi,
>>> I have upgraded from GDAL 1.6 (32bit Windows) to 1.7 (64 bit Windows) and
>>> the following command no longer works:
>>> C:\mapserver\bin\gdal\apps\gdalwarp C:\Data\Rasters\MiscSuit.tif
>>> C:\RasterClips\mytest.tif -cutline c:\RasterClips\hello.json -te
>>> 118008.672141 177232.164284 138695.761666 206164.398565 -dstnodata -9999
>>> I get the following message in the command prompt:
>>> Creating output file that is 414P x 579L.
>>> Processing input file C:\Data\Rasters\MiscSuit.tif.
>>> for band 1, destination nodata value has been clamped to 0, the
>>> original value being out of range.
>>> ERROR 1: Failed to parse CUTLINE geometry wkt.
>>> The CUTLINE is valid GeoJSON (but would clearly be invalid WKT) and
>>> produces the correct results in 1.6.
>>> The ogr formats lists GeoJSON as read/write.
>>> I am using 64-bit builds of GDAL taken from http://vbkto.dyndns.org/sdk/
>>> I have also tried using the development version of GDAL 1.8dev but get
>>> the same message. If I do not use a CUTLINE the gdalwarp completes
>>> successfully but the new image does not contain any data from my original
>>> image (all cells are NoData).
>> Seth,
>> Can you make the .json file available? Does it work with OGR? Try
>> ogrinfo on it.
>> Hmm, tracking through the code the LoadCutline() function in gdalwarp.cpp
>> will read from the OGR datasource and convert the geometry to WKT which is
>> attached to the cutline property of the warp. Later GDALWarpOperation::
>> Initialize() turns that into a polygon object and that is where the
>> message
>> is coming from. So I am *suspecting* improper WKT of some type is getting
>> produced somehow. We will really need to see the WKT that is causing the
>> error to know more.
>> If you are comfortable rebuilding things then try changing:
>> const char *pszCutlineWKT =
>> CSLFetchNameValue( psOptions->papszWarpOptions, "CUTLINE" );
>> if( pszCutlineWKT )
>> in the file gdal/alg/gdalwarpoperation.cpp to something like:
>> if( pszCutlineWKT )
>> printf( "WKT = %s\n", pszCutlineWKT );
>> Best regards,
> Thanks very much for your reply Frank.
> I have uploaded the GeoJSON to
> http://geographika.co.uk/downloads/test.json
> Running ogrinfo C:\test.json on the file produces the following results:
> ERROR 4: GeoJSON Driver doesn't support update.
> Had to open data source read-only.
> INFO: Open of `C:\RasterClips\hello.json'
> using driver `GeoJSON' successful.
> 1: OGRGeoJSON (Polygon)
> Is it possible to use the ogr2ogr to convert GeoJSON to WKT to check if
> this is successful? WKT is not in the list of formats at
> http://www.gdal.org/ogr/ogr_formats.html
> Compiling a 64bit version of GDAL is on my list of things to learn, so I
> will try your second suggestion then.
> The gdalwarp with the same GeoJSON works in 1.6 but it does throw up the
> warning that:
> "the source raster dataset and the input vector layer do not have the same
> SRS. Results will be probably incorrect."
> Regards,
> Seth
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101121/6b3a88cb/attachment-0001.html
