[gdal-dev] Re: Unable to load CIB datasets with GDAL
morabit b.morabito at tdnet.it
Sun Nov 21 15:17:28 EST 2010
 Thank you for your quick response.
I try to build the nitfdump utility on windows XP
with the following command executed in $(GDAL_HOME)\frmts\nitf:
nmake -f makefile.vc nitfdump.exe
but I receive some linker erros:
nitfbilevel.obj : error LNK2019: riferimento al simbolo esterno
_TIFFReadEncodedStrip non risolto nella funzione _NITFUncompressBILEVEL
nitfbilevel.obj : error LNK2019: riferimento al simbolo esterno _TIFFClose
Can you tell me where I can find a pre-built version of nitfdump to quickly
perform the
test you suggested?
Besides, I've created a ticket in GDAL trac for this issue with the same
content
as the posted message.
My development team and me are waiting for a solution
to this problem as it is very urgent for us.
Thank you so much for your attention.
Best regards
Bruno M.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-load-CIB-datasets-with-GDAL-tp5756271p5760905.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
