[gdal-dev] Delete a sqlite database
Ludovic Granjon ludovic.granjon at u-bourgogne.fr
Mon Nov 22 04:26:26 EST 2010
Hi all
I try in a python script to delete a sqlite database that I use in an
OGR ExecuteSQL.
Let me give you an example :
If I do :
 >>> from osgeo import *
 >>> import os
 >>> datasource = ogr.Open("decoupe.shp")
 >>> layer = datasource.GetLayer()
 >>> joinLayer=datasource.ExecuteSQL("SELECT decoupe.FID as ligne_id,
c.lFid as ligne_id2, c.count as count FROM decoupe LEFT JOIN
'project.sqlite'.comptage c ON decoupe.FID=c.lFid")
 >>> datasource.Destroy()
It seems that there still a connection to my sqlite database and I can't
delete it.
When I try on MS Windows (There's no error on linux) :
 >>> os.remove('project.sqlite')
I have :
File "<pyshell#5>", line 1, in <module>
WindowsError: [Error 13] Le processus ne peut pas accéder au fichier car
ce fichier est utilisé par un autre processus: 'project.sqlite'
Do you know a way to do that ?
Thanks
Best regards
Ludovic
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101122/f1006fad/ludovic_granjon.vcf
