[gdal-dev] Re: UnsatisfiedLinkError with gdal14
Tamas Szekeres szekerest at gmail.com
Mon Nov 22 16:26:33 EST 2010
Do you have any compelling reason to use gdal14 instead of a newer version?
You may download working binaries (along with the java bindings) from here:
http://vbkto.dyndns.org/sdk/
Best regards,
Tamas
2010/11/22 MarvinCO <marvin.offiah at googlemail.com>
> I'm sorry, nothing has helped so far. I found out via Dependency Walker,
> that
> obviously there are a few DLLs that gdal14 depends on:
> ieframe.dll
> shlwapi.dll
> urlmon.dll
> I found all of them and placed them into my jre\bin directory. However,
> that
> still doesn't solve my problem. Still getting the same error message. I
> hope
> this output of Dependency Walker is of any help? Look at the tree of
> ieframe.dll. Does this mean that there are some functions not implemented
> in
> the ieframe.dll that gdal14 wants to use?
> http://osgeo-org.1803224.n2.nabble.com/file/n5763694/gdal14.png
> http://osgeo-org.1803224.n2.nabble.com/UnsatisfiedLinkError-with-gdal14-tp5759026p5763694.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101122/2fe1527e/attachment.html
