[gdal-dev] Reprojecting a tiled dataset
Tue Nov 23 19:52:01 EST 2010
Mike Leahy wrote:
> Hello list,
> I'm wondering if anyone has any recommendations for reprojecting a large,
> already-tiled RGB GeoTiff image dataset.  It's straightforward enough to script
> the reprojection of individual tiles, but this leaves black wedges on the
> sides.  I can merge tiles and add '-n 0' to treat the black wedges as no data,
> and the merged output looks fine with no visible black strips, but this is a
> dataset that is of the order of 60GB, so merging all of the tiles takes a
> particularly long time.
> I thought maybe I could use gdal_retile.py...except that doesn't include an
> arugment that allow for the exclusion of a particular nodata value in the
> output.  I figure I could incorporate something to account for nodata into a
> customized version of gdal_retile.py script...would anyone have any pointers
> for doing this?
Mike,
I would suggest using gdalbuildvrt to build a virtual dataset
referencing all the tiles, and then gdalwarp that.  I'd suggested
including "-co TILED=YES" in the gdalwarp command to produce an internally
tiled output GeoTIFF file.
Best regards,
