[gdal-dev] Re: loading kc50 palsar datasets in GRASS
maning sambale emmanuel.sambale at gmail.com
Thu Nov 25 03:57:56 EST 2010
Follow-up on the, from the website:
*2. HH and HV polarization data are kept in BSQ format. Color
composition of the image data is R=HH, G=HV, B=HH/HV and enhanced.
In gdal docs reference to bsq is in the envi format:
http://www.gdal.org/frmt_various.html#ENVI
On Wed, Nov 24, 2010 at 6:21 PM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Anyone successfully loaded kc50 palsar raw imagery with gdal?
> ---------- Forwarded message ----------
> From: maning sambale <emmanuel.sambale at gmail.com>
> Date: Tue, Nov 23, 2010 at 4:00 PM
> Subject: loading kc50 palsar datasets in GRASS
> To: grass-users at lists.osgeo.org
> This site provides PALSAR 50m Orthorectified Mosaic Product.
> http://www.eorc.jaxa.jp/ALOS/en/kc_mosaic/kc_mosaic.htm
> I tried running gdalinfo to the directory, img and header files, but
> gdal doesn't recognize the format.  There is pdf (below the webpage)
> but I can't find any reference to the file formats that is supported
> by GDAL and GRASS.  Has anyone used this dataset in GRASS?
> PS.  This is the only dataset without clouds I can find for my study
> area (for obvious reasons :)).
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> cheers,
> maning
cheers,
maning
