[gdal-dev] RFC 31 - OGR 64bit Support
Even Rouault even.rouault at mines-paris.org
Mon Nov 29 09:57:11 EST 2010
David,
yes, on most 64bit platforms, sizeof(long long)=sizeof(long)=8. Except on Win64,
where sizeof(long) still = 4 ( see
http://en.wikipedia.org/wiki/64-bit#Specific_C-language_data_models ). And of
course on 32bit platforms, sizeof(long)=4. So the need for an explicit 64bit API
is needed.
> Guys,
> Just fyi, a long on my machine (Linux 2.6.35.6-48.fc14.x86_64) is 8
> bytes.   It's the same as long long.
> Dave
> On 11/28/2010 02:39 PM, Even Rouault wrote:
> > Frank,
> > If I agree we can upgrade the C++ API of OGRLayer::GetFeature() and
> > DeleteFeature() to use GIntBig instead of long, I'm wondering whether the
> ABI
> > backward incompatible change of OGR_L_GetFeature() and
> OGR_L_DeleteFeature()
> > is something acceptable with respect to our (implicit) policy and past
> > practices as far as the C ABI is concerned ? I don't remind of such a
> > precedent in the 1.X series (at least since X>= 4). Couldn't this be
> "solved"
> > by introducing OGR_L_GetFeature64() and OGR_L_SetFeature64() and let
> > OGR_L_GetFeature() and OGR_L_SetFeature() do the cast from long to GIntBig
> ? I
> > acknowledge this isn't pretty...
> > Or, if we don't want the OGR_L_GetFeature64/SetFeature64 symbols to be too
> > apparent, we could also use a little trick like the following one :
> > * in ogr_api.h :
> > /* Do not use OGR_L_GetFeature64() directly. Use OGR_L_GetFeature instead
> > /* OGR_L_GetFeature64() will be renamed OGR_L_GetFeature() in GDAL 2.0 */
> > OGRFeatureH CPL_DLL OGR_L_GetFeature64( OGRLayerH, GIntBig );
> > #define OGR_L_GetFeature OGR_L_GetFeature64
> > That way, application code recompiled against the GDAL 1.8.0 header will
> use
> > the 64bit version implicitely.
> > * and in ogrlayer.cpp :
> > /* Hack to preserve GDAL<  1.8.0 ABI : to be removed for GDAL 2.0 */
> > #undef OGR_L_GetFeature
> > OGRFeatureH CPL_DLL OGR_L_GetFeature( OGRLayerH hLayer, long nFeatureId );
> > OGRFeatureH OGR_L_GetFeature( OGRLayerH hLayer, long nFeatureId )
> > 	return (OGRFeatureH) ((OGRLayer *)hLayer)->GetFeature(
> > (GIntBig)nFeatureId );
> > OGRFeatureH OGR_L_GetFeature64( OGRLayerH hLayer, GIntBig nFeatureId )
> > 	return (OGRFeatureH) ((OGRLayer *)hLayer)->GetFeature( nFeatureId );
> > that way the old symbol and the new symbol are available...
> > Concerning the impact of introducing OFTInteger64 for existing
> applications,
> > it is not obvious to predict it. From a quick "grep OFTInteger" in 2
> popular
> > applications :
> > * MapServer would need a minor update in mapogr.cpp. If code left as it is
> > now, OFTInteger64 fields would be advertized as 'Character' fields in the
> GML
> > schema instead of Integer with appropriate width (the only case OFTInteger
> in
> > mapogr.cpp). Also, I'm not sure if the OGR field type is tested indirectly
> > afterwards in the vector rendering/expression evaluation or if just a
> atof()
> > is done on the field value. And in the new mapogroutput.c, according to the
> > width of a item->type == "Integer", we could appropriately create a
> > OFTInteger64.
> > * The OGR provider in QGIS if unchanged would also present OFTInteger64
> fields
> > as QVariant::String fields as a default (but the values couldn't be
> > edited/updated). I see that other QGIS providers use QVariant::LongLong, so
> > OFTInteger64 could potentially be properly supported. Other places such as
> > src/core/qgsvectorfilewriter.cpp currently turns QVariant::LongLong into
> > OFTString when creating the OGR fields and could also be updated.
> > So if unchanged, it *looks* like those applications should still go on
> working
> > (at least not crashing), but with perhaps a bit degraded functionnality
> w.r.t
> > to the current situation (where the big integers are returned as double for
> > shapefiles). For MapServer case, this is mitigated since OGR isn't actually
> > used for access to shapefiles and postgis ...
> > Best regards,
> > Even
> >> Folks,
> >> In the interest of moving towards a GDAL/OGR 1.8 release I have done some
> >> work on RFC 31 - 64bit integers for OGR fields and FIDs.  I've updated the
> >> RFC itself somewhat, and done a preliminary implementation of the RFC on
> >> my own system with a reasonable level of success.
> >> I'm asking for additional comment on the RFC at:
> >>     http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64
> >> The implications and complications of this update are greater than I had
> >> first anticipated and even with what I've done so far I'm sure lots of
> >> additional glitches will come out of the wood work.  Unfortunately, this
> >> is not funded work for me so it is hard to apply the level of effort that
> >> I would like to it.  In short, I'm a bit nervous about implementing this
> >> RFC though now that I've sunk 2-3 days into the prototype work I'm
> hesitant
> >> to throw it away either. :-)
> >> Thoughts welcome.
> >> Best regards,
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
