[gdal-dev] PG: does OGR2OGR set the SRID correctly ?
Sebastian E. Ovide
sebastian.ovide at gmail.com
Tue Nov 30 09:23:36 EST 2010
I've replaced the -lco 27700 with -a_srs EPSG:27700
now select ST_SRID(wkb_geometry) from sebas
gives 4...
any ideas ?
On Tue, Nov 30, 2010 at 10:59 AM, Even Rouault <even.rouault at mines-paris.org
> wrote:
> Selon "Sebastian E. Ovide" <sebastian.ovide at gmail.com>:
> Sebastian,
> The option "-lco 27700" has no effect. The correct syntax would be
> something
> like "-lco SRID=27700", but there's no such option, so don't loose your
> time
> trying that ;-)
> The SRID is set automatically by comparing the SRS of the source layer with
> what
> exists in the spatial_ref_sys table (or the one you can set with the -a_srs
> EPSG:27700 as suggested by Jorge). If there's a match, then the SRID from
> spatial_ref_sys will be used. Otherwise the PG driver will add a new entry
> in
> the spatial_ref_sys table (and the SRID number will not be equal to the
> EPSG
> code). Make sure you've filled the spatial_ref_sys table
> with the appropriate PostGIS .sql script. The '3' you get sounds like the
> spatial_ref_sys table of this database was empty and that the PG driver
> added
> new entries in it.
> Best regards,
> > Hi All,
> > I've just uploaded a shape with
> > ogr2ogr -f PostgreSQL "PG:dbname='gis' host='10.0.1.40' port='5432'
> > user='gis' password='gis'" sebas.shp -lco 27700 -lco PRECISION=NO
> -progress
> > -lco OVERWRITE=yes -lco dim=2 -nln sebas -overwrite
> > but from
> > select ST_SRID(wkb_geometry) from sebas;
> > I'm getting 3
> > (with
> > select ST_SRID(ST_SetSRID(wkb_geometry,27700)) from sebas;
> > I'm getting the right value )
> > any ideas ?
> > Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101130/837ff18f/attachment-0001.html
