[gdal-dev] Creating a range from given points
Kevin dingojones22 at gmail.com
Tue Nov 30 10:26:34 EST 2010
 Dear list,
Please see in attached image what I am aiming to achieve with GDAL.
The tool creating it is here, but I don't have arcgis:
http://resources.arcgis.com/fr/gallery/file/geoprocessing/details?entryID=1FECB539-1422-2418-7FE1-77F9D088402D
The input is a set of points and a fixed grid (10x10km).
The output a subset of the grid based on the points with the cells
interlinked by some logic.
My idea (probably not optimal):
- convert the points to gridcell centroids
- draw a line between the point and its neighbours
- if the distance is inferior to a certain value -> intersect the line with
the grid and keep the intersected cells
- result: assemble resulting cells and export
Not being a spatial expert, I'm not sure though this is the good way. Could
you have a look and perhaps give me a few hints?
Thanks a lot!
Kevin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101130/0ce170fe/attachment.html
