[gdal-dev] unresolved CPLAtomicAdd
Clay, Bruce bclay at ball.com
Tue Nov 30 21:27:37 EST 2010
I have been using GDAL 1.7.1 for a while now in debug mode without problems.  I recently compiled GDAL in release mode and did not see any errors during the build process.
When I build my application I get the following link error : "unresolved external symbol _CPLAtomicAdd".  I can see cpl_atomic_ops.obj after the build process so I know the method is getting compiled.  I don't have this error in debug mode.
Has anyone seen this problem and have a fix?
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101130/824344c7/attachment.html
