[gdal-dev] ERROR 4: ... is a grib file, but no raster dataset was successfully identified.
Hermann Peifer peifer at gmx.eu
Mon Oct 4 10:28:01 EDT 2010
  On 04/10/2010 15:21, Cassanova, Bill wrote:
> As a suggestion give wgrib2 a try.  If it fails as well there is
> something not quite correct in the grib2 itself.
> I have seen this error before and the problem was exactly that.
Thanks for the hint! You are right: wgrib2 doesn't like the file either:
$ wgrib2 HRES_ENS_2010100300+000.grib2
*** FATAL ERROR: rd_grib2_msg, missing end section ('7777') ***
It looks like I better contact the data provider.
Hermann
