[gdal-dev] Re: gdal_rasterize -tr and -te
Mon Oct 4 11:23:47 EDT 2010
Hermann Peifer wrote:
> On 04/10/2010 16:31, Even Rouault wrote:
>> This raises quite a few questions :
>> * what is a standard grid ?
> Ours starts at 0,0, then goes in all directions with the given tr
>> * what syntax would you imagine to pass to gdal utilities to define
>> how you want
>> the rounding ?
> Some creation options like standard=yes, standard_origin=0,0
>> * do you want to round/ceil/floor ? or so that the adjusted extent
>> includes the
>> exact extent ? or so that the adjusted extent is contained inside the
>> exact
>> extent ?
> The adjusted extend includes the exact extent.
>> * which gdal utilities would be impacted ?
> All the ones that create new raster files: gdal_rasterize,
> gdal_translate, gdalwarp, ...
Even,
I would suggest "-tap" for "target aligned pixels" to go with "-tr".  I
would think that gdalwarp, gdal_rasterize, and perhaps gdal_merge.py and
gdalbuildvrt would be appropriate applications to support this switch.
I don't see how it would be appropriate for gdal_translate.
Best regards,
