[gdal-dev] Mixed line endings in released gdal172.zip (sagadataset.cpp)
Mon Oct 4 12:04:43 EDT 2010
Todd Jellett wrote:
> FYI There are mixed line endings (unix/windows) in the released version
> of gdal172.zip obtained here
> (http://trac.osgeo.org/gdal/wiki/DownloadSource).
> This is causing a subversion problem when attempting to do a "Vendor
> Update" from v1.6.0 to v1.7.2 which preserves our local changes
> (nmake.opt  + makefile.vc). It doesn't matter which line ending is used,
> it just can't be mixed in the same file. The issue is described here:
> http://svn.haxx.se/users/archive-2006-07/0702.shtml
> The only file with mixed line endings is sagadataset.cpp (but this one
> file is enough to cause svn to barf) .
Todd,
I have corrected this file in trunk and the 1.7 branch.  The next GDAL 1.7.x
release should not have this issue.
Best regards,
