[gdal-dev] Memory usage for GetProjectionRef
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Oct 5 03:35:46 EDT 2010
Livneh,
I am assuming the 80KB refers to the memory change for getting the
projection and not the whole dataset.
Can you check if the 80KB memory is freed and not leaked if the dataset is
closed?
On Mon, Oct 4, 2010 at 10:41 PM, Livneh Yehiyam <yehil at rafael.co.il> wrote:
> Hi
> We are using Gdal 1.7.0b from FWTools 2.7.1.
> Our application is written in C#.
> In our application we need to open a large number of tiff files (more than
> 2000).
> We noticed that opening a dataset and then getting the projection string
> will increase the amount of memory (private bytes) by more that 80KB. This
> seems not a large amount, but multiplied by 2000 is more than 160MB.
> Is anyone aware of such a problem?
> Sent from my mobile
> * This message (including any attachments) issued by RAFAEL- ADVANCED
> DEFENSE SYSTEMS LTD. (hereinafter "RAFAEL") contains confidential
> information intended for a specific individual and purpose, may constitute
> information that is privileged or confidential or otherwise protected from
> disclosure. If you are not the intended recipient, you should contact us
> immediately and thereafter delete this message from your system. You are
> hereby notified that any disclosure, copying, dissemination, distribution or
> forwarding of this message, or the taking of any action based on it, is
> strictly prohibited. If you have received this e-mail in error, please
> notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely
> delete or destroy any and all electronic or other copies of the original
> message and any attachments thereof. *
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101005/09e5658e/attachment.html
