[gdal-dev] Re: gdal_rasterize -tr and -te
Hermann Peifer peifer at gmx.eu
Wed Oct 6 10:20:55 EDT 2010
On 06/10/2010 15:20, Hermann Peifer wrote:
> On the other hand...
> The new, target aligned tiffs do only have NODATA values, which seems to
> be related to ERROR 1:
> $ gdal_rasterize --debug on --config GDAL_CACHEMAX 2000 -ot byte
> -a_nodata 0 -co compress=lzw -tr 255 255 -tap -l lu001l_luxembourg -burn
> 1 -where CODE=111 lu001l_luxembourg.shp out.tif
> OGR: OGROpen(lu001l_luxembourg.shp/0x1978ae0) succeeded as ESRI Shapefile.
> GDAL: QuietDelete(out.tif) invoking Delete()
> GDAL: GDALOpen(out.tif, this=0x19cbe00) succeeds as GTiff.
> GDAL: GDALDefaultOverviews::OverviewScan()
> GDAL: GDALClose(out.tif, this=0x19cbe00)
> GDAL: GDALDriver::Create(GTiff,out.tif,224,321,1,Byte,0x1979ab0)
> ERROR 1: Type mismatch or improper type of arguments to = operator.
> GTiff: Adjusted bytes to write from 8064 to 7392.
> GDAL: GDALClose(out.tif, this=0x19caf40)
> GDAL: GDALDeregister_GTiff() called.
> I am not sure if this new ERROR is related to your patch or some other
> changes which came through checking out -r 20770.
I see: ERROR 1 can be avoided by using: -where CODE=\'50000\' (CODE is a
string field). In any case: I rasterize via a shell script and I did not
get the same error when running the same script last week.
Hermann
