[gdal-dev] Re: gdal_rasterize -tr and -te
Hermann Peifer peifer at gmx.eu
Wed Oct 6 10:40:36 EDT 2010
On 06/10/2010 16:34, Frank Warmerdam wrote:
> Hermann Peifer wrote:
>>> $ gdal_rasterize --debug on --config GDAL_CACHEMAX 2000 -ot byte
>>> -a_nodata 0 -co compress=lzw -tr 255 255 -tap -l lu001l_luxembourg -burn
>>> 1 -where CODE=111 lu001l_luxembourg.shp out.tif
>>> OGR: OGROpen(lu001l_luxembourg.shp/0x1978ae0) succeeded as ESRI
>>> Shapefile.
>>> GDAL: QuietDelete(out.tif) invoking Delete()
>>> GDAL: GDALOpen(out.tif, this=0x19cbe00) succeeds as GTiff.
>>> GDAL: GDALDefaultOverviews::OverviewScan()
>>> GDAL: GDALClose(out.tif, this=0x19cbe00)
>>> GDAL: GDALDriver::Create(GTiff,out.tif,224,321,1,Byte,0x1979ab0)
>>> ERROR 1: Type mismatch or improper type of arguments to = operator.
>> I see: ERROR 1 can be avoided by using: -where CODE=\'50000\' (CODE is
>> a string field). In any case: I rasterize via a shell script and I did
>> not get the same error when running the same script last week.
> Herman,
> Were you using GDAL 1.7 last week?
No, but an earlier version of 1.8dev (a few months old, perhaps)
Hermann
