[gdal-dev] Re: GDAL JAVA problem
Even Rouault even.rouault at mines-paris.org
Wed Oct 6 13:37:42 EDT 2010
Le mercredi 06 octobre 2010 16:35:38, sagar_sahay a écrit :
> After tweaking the path variable I got this exception:
> Native library load failed.
> java.lang.UnsatisfiedLinkError:
> /home/gdal/gdal-1.7.2/swig/java/libgdaljni.so:
> /home/gdal/gdal-1.7.2/swig/java/libgdaljni.so: wrong ELF class: ELFCLASS64
> (Possible cause: architecture word width mismatch)
> Exception in thread "main" java.lang.UnsatisfiedLinkError:
> org.gdal.gdal.gdalJNI.AllRegister()V
>         at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
>         at org.gdal.gdal.gdal.AllRegister(gdal.java:447)
>         at ogr.gdalinfo.main(gdalinfo.java:57)
> Java Result: 1
> Please Help.
Well, by looking at the error, it looks like you're on a 64bit Linux, so the
binding library has been compiled as 64bit, which is fine. So my guess is that
you're running a 32bit JVM or 64bit JVM in 32bit mode.
