[gdal-dev] Geomedia mdb files
Moskovitz, Bob Bob.Moskovitz at conservation.ca.gov
Tue Oct 12 12:18:20 EDT 2010
Frank,
I'm also interested in seeing a Geomedia driver for gdal.  Btw, gvSIG has a Geomedia plugin (see https://code.google.com/p/extmdb ).  This might help you figure out how to make a driver for gdal.
Bob Moskovitz
Seismic Hazards Mapping Program
California Geological Survey
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org on behalf of Frank Warmerdam
Sent: Tue 10/12/2010 7:59 AM
To: Zoltan Szecsei
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Geomedia mdb files
Zoltan Szecsei wrote:
> Hi,
> Is there an opensource read/write capability for Geomedia Access MDB files?
> If not, are there any "work in progress" attempts?
> I see they are "Standard Jet DBs", but the geometry coordinates seem to
> be in a BLOB field.
zoltan,
I am not aware of an open source geomedia reader, though I've discussed
it with a few people from time to time.  I not aware of the BLOB format
but I suspect a sustained effort could lead to a decoding of it.
Best regards,
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
