[gdal-dev] Re: combine shapefiles?
Hermann Peifer peifer at gmx.eu
Wed Oct 13 12:44:05 EDT 2010
On 13/10/2010 09:10, Jukka Rahkonen wrote:
> However, the .shp part of shapefile can not grow bigger than 4 gigabytes.
Did you ever succeed in creating a, say: 3.9G .shp file?
I do remember that some time ago, I was running into problems around 2G,
which wasn't too much of a surprise, as [1] suggests that:
 > There is a 2 GB size limit for any shapefile component file,...
Hermann
[1]
http://webhelp.esri.com/arcgiSDEsktop/9.3/index.cfm?TopicName=Geoprocessing_considerations_for_shapefile_output
