[gdal-dev] cubic / bilinear resampling with gdalwarp looks similar to nearest neighbour
Wed Oct 13 23:48:31 EDT 2010
Craig de Stigter wrote:
> Apologies for the long delay. I've finally had opportunity to look into
> this again.
> I'm still unsure why exactly the bilinear and bicubic resampling
> produces such second-rate output in GDAL. I have a few questions:
> 1. Is there a fundamental reason why the bilinear resampling couldn't
> use all the pixels from the source region, rather than just the 4 corner
> pixels? A destination pixel would then be the weighted average of all
> the source pixels for each band.
Craig,
Well, it would no longer be bilinear.  It would be averaged.
> 2. Suppose a 1/6 sampling ratio, i.e. a 6x6 region (0, 0)-->(6, 6) in
> the source image corresponds to a 1x1 region in the output.
> What source pixels are used by the bilinear resampling in GDAL?
> Wikipedia <http://en.wikipedia.org/wiki/Bilinear_interpolation> suggests
> it should be the 'nearest' four pixels to the desired destination pixel,
> i.e. (2, 2), (2, 3), (3, 2), (3, 3). Is that what GDAL is doing, or is
> it using (0, 0), (0, 5), (5, 0), (5, 5) ?
It will use (2, 2), (2, 3), (3, 2), (3, 3).
> 3. Assuming a 'no' answer to (1), if I were to contribute a patch to
> make bilinear/bicubic resampling take all the source pixels into
> account, would it meet much opposition? It would probably make
> large-scale downsampling using these methods much slower, though its
> questionable whether anyone would complain given that the quality of
> current output is so poor...
I'm not adverse to your preparing a patch that implements an
"averaged" resampling kernel, but it doesn't replace bilinear.
Generally speaking the warper is not intended for dramatic changes
of resolution - it is intended for changes of geometry at roughly the
same resolution - for instance reprojection.
Average was already implemented as a resampling kernel in the
"build overviews" tool because it is aimed at dramatic changes of
resolution.
Best regards,
