[gdal-dev] tileindex performance
Elijah Robison elijah at villagis.com
Thu Oct 14 13:02:14 EDT 2010
Hi Nikos,
I also have difficulty tiling large, high res images with gdal_retile.
I would say our average process--a county-wide, 1-foot resolution
ECW--takes about a month to run to completion.
At first, tiles are generated with blazing speed.  But by the time the
routine has been running for about 24-hours, it slows to a crawl.  Is
this the symptoms you are experiencing or are you running into something
else?
I would very much love to get to the bottom of this and find a way to
maintain the original performance throughout a tiling routine.
Best, Elijah Robison
nickos85 wrote:
> Hi,
> I have a mapserver and a high resolution image about 4GB when i make the
> image tiles with a size of 512x512 using gdal_retile I have better result
> instead of a tile size of 256x256. I think the problem is on how the search
> algorithm for the location of the tile can be improoved. Any suggestions?
> --Nikos Hatzopoulos
